Super nitpicky, but the way the phrase is used, it's talking about nodes, not necessarily forums.
It's used when you add a new node. I noticed it while creating some new node type options (that are most definitely nothing related to forums).
Digging a little further, the same phrase is used for other non-forum...
if_entered_url_to_forum_not_contain_id_change_breaks_urls said:if_entered_url_to_forum_not_contain_id_change_breaks_urls said:
If entered, the URL to this forum will not contain an ID. Use a-z, 0-9, _, and - characters only. Note that once specified, changing this value will cause URLs to be broken.
