ThanosCrax
xnforo.ir
Hhhhh nice
I'm using litespeed cache however stilllightspeed or lighttpd
they are fast![]()
I knew what is the problemI'm using litespeed cache however still![]()
HmmmI knew what is the problem
There are 2 things to look into:
your website is about hacking and cracking, cloudflare isn't that good if server is not DDOS protected, you might be under attack
1- you need to do some iptables work+ sysctl tweaking, switch congestion controller to "hybla"
2- Optimize your XenForo database from admin cp
if you're using container VPS(Openvz) then you will have bad experience, server resources will be shared.(Slow)
Switch to KVM.
note if you're on HDD not SSD then cache will slow down website more. (Switch To SSD)
many factors can cause poor performance![]()
