No Increase In Post Count for Short Posts
Add-ons No Increase In Post Count for Short Posts 1.0a
XenBot
Supervisor
  • Staff
XenBot submitted a new resource:
No Increase In Post Count for Short Posts - Posts not reaching the character limit are not counted towards the user's post coun
This add-on allows you to pick an array of forums and a character limit. In the selected forums, if the character count of a post is lower than the character limit then that post does not get counted towards the user's post count.
This should help achieve better interaction from your users, with less of a temptation to make short posts.
INSTALLATION
This add-on supports the Add-On Installer. You can simply download the zip archive and upload using the Add-On Installer option...
