PixelYourSite PRO - Powerful WordPress Plugin for FaceBook
WP Plugins PixelYourSite PRO - Powerful WordPress Plugin for FaceBook 8.3.2 Nulled
  • #6
XenForo updated PixelYourSite PRO - Powerful WordPress Plugin for FaceBook with a new update entry:
PixelYourSite PRO v8.0.7 Nulled
PixelYourSite Pro 8.0.7
  • Fix for a potential problem with AddToCart not being fired on single product pages.
  • Fix for a potential problem with the AddToCart fired twice on single product pages.
  • Fix for a potential problem with the mobile menu of the Porto theme.
  • Fix for a potential conflict between the Bing add-on and a product filter plugin.
  • Update for the Facebook CAPI help link inside the plugin.
  • #7
PixelYourSite PRO v8.2.0
PixelYourSite Pro 8.2.0
  • UI changes
  • A new way to verify domains for the supported tags directly from the main page. This is an alternative to verifying domains with the plugin’s Head and Footer feature. If you use that already, you don’t need to change it.
  • Facebook Conversion API events will have an External ID when possible. This will improve matching for CAPI events.
  • Fix for a potential error related to Facebook Advanced Matching data for...
  • #8
PixelYourSite PRO v8.3.2 Nulled
PixelYourSite Pro 8.3.2
  • New options to turn ON/OFF most global, WooCommerce, Easy Digital Downloads events parameters. Use it if Facebook shows privacy warnings related to some parameters. You have a video about it linked on the plugin’s main page.
  • New option to remove URL parameters from the target_url Signal parameter. Default is ON, to avoid sending potential private data to Facebook.
  • WooCommerce 5.3 compatibility check.
  • Some other code improvements and small bug...
    pixelyoursite pro v8.2.0 pixelyoursite pro v8.3.2 nulled
