Changelog:
All themes
1.
Framework
- Updated to Xenforo 2.2.7.1, merged all templates
- Updated modified templates to use latest Xenforo versions
- Moved all themes to use the new Xenforo asset system.
- All references to the @xf-themePath style property have been replaced with %ASSET%:style
2.
Misc Improvements
- Adjusted custom style property labeling and ordering in several custom property groups
- Optimized several custom Less templates
Pro themes
1. Misc Improvements
- Removed some deprecated templates for lighter file package and XML size
- Removed the default value of "0" from the custom Logo small width & height fields in Style Properties -> Basic options
2. Messages
- Changed the default avatar size to Small when the user info column in messages is set to the above position
- The custom style property for the User Extra Details wrapper (which contains things like Join Date, Trophies, Reactions etc) no longer applies when the user info column is set to the above position. This helps prevent some unwanted style bugs which may be improved in a later version.
- The user info column has been set to the above position in all advanced graphical gaming themes (Aftermath, Headquarters, Enforcer etc). This helps to allow greater space for post content due to the condensed nature of these themes.
3. Carousels
- Carousel items in the [Nulumia] Icon Slider property group now support uploading custom images via the Xenforo asset system
4. Slider
- Slides in the [Nulumia] Slider property group now support uploading custom images via the Xenforo asset system
5. Backgrounds
- Theme background images in the [Nulumia] Background Settings property group now support uploading custom images via the Xenforo asset system
6. Footer
- Removed the Flickr sample widget from column 3 in some themes, due to that functionality no longer being supported
7. Addon Related
- Updated several templates for DragonByte Tech eCommerce
- Removed support for SyTry mobile online/offline addon temporarily, this should be fixed in a future version.
Overview:
This update brings compatibility with the latest Xenforo 2.2.7 Patch Level 1. Further, the theme file structure in all themes has changed. It is important you must upload all files in your download package and overwrite if prompted.
Notice on One-Click Archive imports:
This will be the final version before all Nulumia themes move to support importing via one-click archives. As such, you must still manually install/upgrade this theme by unzipping & uploading files, then importing the XML over your existing theme.
In the next version, you will have the option of downloading the archive format, or full file package which will include optional files, such as PSDs, readme.txt, etc.
Notice of changed file structure:
- In this version (2.2.7.1), the theme file structure has changed. You must upload all files for your theme to work correctly. Further, if you have referenced images or other files in the previous theme location, they will continue to work if you leave existing files present on your server.
- When one-click archive support is added to next releases, all themes files will be located in the /data/styles/ directory. Additional details & instructions will be provided at that time if you wish to migrate custom files.
- Now with support for the Xenforo asset system!
- In recent versions, Xenforo added the new Asset system, which not only improves style installation and upgrades with one-click archive support, but also provides easy uploading of images within Style Properties.
- To follow correct syntax in preparation of one-click archive support, all references in Nulumia themes to the @xf-themePath style property have been replaced with %ASSET%:style. Likewise, template references to {{ propery('themePath') }} have been replaced with {{ asset('style') }}.
Here's just some of the popular features which support instant uploads!
1.
[Nulumia] Backgrounds Settings:
Xenforo 2 themes nulumia styles asset system backgrounds
2.
[Nulumia] Icon Slider:
3.
[Nulumia] Slider:
Xenforo 2 themes nulumia styles asset system slider
It has no doubt been an inconvenience to manually upload images to the web and place their URLs for using these features. But no more! These and more upcoming features will now be as easy as possible to use.
Q:
Where will files go using the new upload feature?
A: All uploaded files will be placed in the /data/ directory. Different features in Nulumia pro themes will be found in labeled sub-directories, to keep things tidy from other themes on your site:
/data/nl-background
/data/nl-carousel
/data/nl-slider
etc.
