i try all things but still
i cannot proceed unless all XenForo database tables are removed.
Good, this sentence tells us exactly where the wall is.
What XenForo is saying now is very literal:
I will not continue as an installer unless the database is completely empty of XenForo tables.
So the problem is
not files, not config.php,
not cache. It is
100% the database.
Let’s fix it cleanly, step by step, no guessing.
Why this keeps happening
Even if you:
re-upload files
delete /install
fix config.php
as long as the database still contains XenForo tables, the installer will refuse to proceed unless it’s allowed to delete them.
XenForo detects tables like:
xf_user
xf_post
xf_thread
xf_option
xf_addon
If
any of these exist → installer blocks.
Solution 1 (BEST & SAFEST): create a NEW empty database
This avoids mistakes and accidental data loss.
1 - Go to your hosting control panel (cPanel / DirectAdmin / etc.)
2 - Create:
a
new database
a
new database user
3 - Assign the user to the database with
ALL privileges
4 - Edit: src/config.php
and change only:
dbname
username
password
5 - Run the installer again.
Result: installer proceeds instantly
Zero conflicts
Recommended by sane admins
Solution 2: manually delete XenForo tables (advanced, destructive)
This
permanently deletes forum data.
1 - Open
phpMyAdmin
2 - Select your database (u584811126_xenforo)
3 - Check all tables that start with:
xf_
4 - Choose
Drop
5 - Confirm deletion
6 - Refresh the database — it must be completely empty
7 - Run the installer again
If even
one xf_ table remains, XenForo will still block.
Very important gotcha (many people miss this)
If your config.php points to:
the
wrong database
or a database with
table prefix enabled
XenForo may still see old tables.
Make sure this matches reality:
$config['db']['dbname'] = 'EXACT_DATABASE_NAME';
$config['db']['prefix'] = '';
No prefix unless you intentionally used one.
About the checkbox
“Remove all XenForo-related data”
If it’s forcing you to check it, that means:
still detects tables
You are
not using a clean database
The checkbox is not the fix.
The database state is the fix.
Final truth (no sugar-coating)
You cannot “convince” XenForo to continue.
You must give it
either:
an empty database
or
permission to delete everything inside it.
Once the database is clean, XenForo becomes very cooperative.
This is not a bug — it’s a guardrail.
If you want, you can paste:
your config.php (with passwords hidden)
or say what hosting panel you use
and I’ll pinpoint the exact misalignment.
