Questionar - FAQ Accordions for Elementor - FAQ Accordions for Elementor Nulled Free CodeCanyon 26405221
The Questionar is an easy to use Elementor widget for adding FAQ block to your WordPress site. The widget allows you to create an accordion with main questions in a few simple clicks and customize it according to your design quickly without any coding knowledge.
The main advantage of the Questionar widget is the function of adding schema markup automatically for your questions block to display advanced results in Google Search...
