Joomla
Joomla submitted a new resource:
ReReplacer PRO - Joomla Management System
ReReplacer Pro enables you to search and replace anything you want in your Joomla website on-the-fly.
ReReplacer can work on the entire output of your site, so you can do replacements in any piece of HTML, including things like meta tags. You can search for something and replace it with something else, or you can simply remove it (by replacing it with nothing).
With ReReplacer, the replacements are done...
