</clown>
Template modification:
Template: PAGE_CONTAINER
Modification key: style_changer
Description: Style changer
Search type: simple replacement
Find:
Replace:
Two modification:
Template: extra.less
Modification key: style_changer_less
Search type: Regular expression
Find:
Replace:
Result:
Find:
HTML:
<div class="p-navgroup p-discovery{{ !$xf.visitor.canSearch() ? ' p-discovery--noSearch' : '' }}">
HTML:
<xf:set var="$styleLight" value="3" /> <xf:comment>Light style. Specify the id of the style in the value.</xf:comment>
<xf:set var="$styleDark" value="2" /> <xf:comment>Dark style. Specify the id of the style in the value.</xf:comment>
<xf:set var="$styleTitle">
<xf:if is="$xf.style.style_id == $styleLight">
{{ {$xf.language.language_code} == 'ru-RU' ? 'Включить темный стиль' : 'Enable dark style' }}
<xf:elseif is="$xf.style.style_id == $styleDark" />
{{ {$xf.language.language_code} == 'ru-RU' ? 'Включить светлый стиль' : 'Enable light style' }}
</xf:if>
</xf:set>
<xf:if is="$xf.visitor.canChangeStyle()">
<div class="p-navgroup p-discovery">
<a href="{{ link('misc/style', null, {
'style_id': $xf.style.style_id == $styleLight ? $styleDark : $styleLight,
'_xfRedirect': $redirect,
't': csrf_token()
class="p-navgroup-link style-changer"
data-xf-init="tooltip" title="{$styleTitle}">
<span class="style{{ $xf.style.style_id == $styleLight ? '-light' : '-dark' }}"></span>
</a>
</div>
</xf:if>
$0
Two modification:
Find:
HTML:
#^.*$#su
CSS:
$0
.p-navgroup-link.style-changer {
span {
&:before {
.m-faBase();
&.style-light:before {
.m-faContent(@fa-var-lightbulb-on);
&.style-dark:before {
.m-faContent(@fa-var-lightbulb);
Result:
