M Mahdia Registered Dec 11, 2022 #6 syntaxbyte said: Can this be customized to work for Auto-Post Delivery? An Addon that will automatically send all post to Telegram Channel/Group Click to expand... This plugin does the same thing
syntaxbyte Registered Dec 16, 2022 #7 Mahdia said: This plugin does the same thing Click to expand... I can't seems to install it. Can you give guidance please? I always see this on webhook setup: Oops! We ran into some problems.The requested page could not be found.
syntaxbyte Registered Dec 16, 2022 #8 XenForo said: Do the file section information carefully Add-ons - [tl] Telegram Integration XenForo with Telegram Bot Integration Telegram BOT with XenForo 2 For more information about Telegram BOT please read this introduce and see what BOT can do. Creating a Bot Open Telegram app and log in your account or create new one if you... xnforo.ir Click to expand... Am seeing "page not found" whenever I tried this: https://mydomain.com/misc/telegram/webhook?set=1
E Ethanist Registered Dec 16, 2022 #9 syntaxbyte said: Am seeing "page not found" whenever I tried this: Click to expand... Did you install the plugin correctly?
syntaxbyte Registered Dec 19, 2022 #10 Ethanist said: Did you install the plugin correctly? Click to expand... Yes, It seems to be installed correctly. Steps: 1. Uploaded the src folder to root 2. Installed from Ad-On (Admin Panel) 3. Tried the Webhook URL?
