duppy XF-Fan Loyal Member Mar 18, 2021 #11 I think I messed up also. The one I have is XF2_2_4 STYLE [TH] UI_X 2 Dark 2_2_4_0_0.
duppy XF-Fan Loyal Member Mar 27, 2021 #12 I noticed that this theme is not storing the saved states of the collapsible nodes, or the theme width for that matter. Any idea how I can fix this? I tried reinstalling the theme, but it does not resolve the issue. Regards, Duppy
WinSys32 Xenforo Developer/Expert Registered Mar 27, 2021 #13 Hi @duppy In the meanwhile their is version 2.2.4.0.0 from this template, probably you should nee to update to that one. Once it's finally released here
duppy XF-Fan Loyal Member Mar 27, 2021 #14 AlexRuter said: Hi @duppy In the meanwhile their is version 2.2.4.0.0 from this template, probably you should nee to update to that one. Once it's finally released here Click to expand... Ok, thanks. I'll do that.
XenForo Administrative Mar 28, 2021 Thread starter Admin #15 XenForo updated [TH] UI.X Classic Dark with a new update entry: Version 2.2.4.0.0 Released Changelog: XenForo 2.2.4 compatibility Added a feature that wraps the nav phrase in span for additional design options with the sidebar navigation Fixed an issue on Legend that caused the login phrase to not be viewable on mobile Fixed an issue that caused meta titles to not work properly Fixed an issue with the overlay blur effect that caused page width issues on mobile when modals are opened Fixed an issue with the Fab button which caused it to show above... Click to expand... Read the rest of this update entry...
