A amir023123 Registered Apr 30, 2021 #16 Marks-Man said: you mean node images doesn't have links ? ( are not clickable as links ? ) Click to expand... yes they are images but they are not links. i want them to go it its node url please
Marks-Man Loyal Member Apr 30, 2021 #17 amir023123 said: yes they are images but they are not links. i want them to go it its node url please Click to expand... hmm that's how the plugin is coded You can add node icons manually it is better than adding links and make them clickable (It needs some work).
A amir023123 Registered Apr 30, 2021 #18 Marks-Man said: hmm that's how the plugin is coded You can add node icons manually it is better than adding links and make them clickable (It needs some work). Click to expand... yes the images are added seperate for each nodes. i installed the custom node add on. so this addon does not have the images go to its url?
Marks-Man Loyal Member Apr 30, 2021 #19 amir023123 said: yes the images are added seperate for each nodes. i installed the custom node add on. so this addon does not have the images go to its url? Click to expand... nope , I don't think so addon needs customization, it can be done but now I am working on another projects
Marks-Man Loyal Member Apr 30, 2021 #20 check my tutorial , add node icons and you can take a further step and add links
