ThanosCrax
Yep but it causes conflict with attachment uploadsUse the above code without installing the plugin
xnforo.ir
Does this add-on work for XFMG?Yep but it causes conflict with attachment uploads
Check this plugin , I fixed bugs and problems
Add-ons - ITM Chevereto Integration (Custom Edit)
LATEST CHANGES: - Support Added For XenForo Resource Manager Solved Attachments problem conflicting with image uploading to external file hostxnforo.ir
yes addon. no not same oneDoes this add-on work for XFMG?
I think it's same as the one above?
Sorry but it worked only with XFRM[Xenforo Resource Manager]yes addon. no not same one![]()
