[RSS Feed/News] Using PHP array_flip with additional_usergroups field
I am trying to understand building usergroup filters for the contents of addons.
In particular, the use of array-flip after merging an array variable with the secondary_group_ids in the xf_users table.I have been studying an addon that uses that technique to effectively create an array all the user_id's that share a common usergroup. The result was a warning level error that did not seem to affect the results. Once I changed the error reporting for that script, everything seems to be...
