D Darcy Registered Jan 11, 2023 #2 Zeus005 said: What does this mean? Help Click to expand... Put this in the config file Code: $config['enableAddOnArchiveInstaller'] = true; And that there is probably a problem with your plugin Upvote 0 Downvote
lil021g Registered Jan 12, 2023 #3 Your plugin probably has a bug or doesn't match your community version, remove the plugin completely and use another one. Upvote 0 Downvote
