I added the media widget to my site and was trying to move it up and down but I can't figure out how it works, I thought it was by using the = or - under display position but the position doesn't change no matter what number I add to the box(s)
Is there a section in the manual that shows me where the widget will show up? IE Forum List: Above Node, Member Wrapper: Sidenav. Some are clear but others are not so much, if it is just try and see what happens I can do that as well.
