WP Adminify PRO - Powerhouse Toolkit for WordPress Dashboard
WP Plugins WP Adminify PRO - Powerhouse Toolkit for WordPress Dashboard 3.1.2
CodeCanyon
  • Moderator
CodeCanyon submitted a new resource:
WP Adminify PRO - Powerhouse Toolkit for WordPress Dashboard - Plugin Nulled Free Premium
WP Adminify PRO NULLED - Increase your site’s efficiency by powering up your WordPress Dashboard in a few easy clicks!​
Organise your dashboard the way you need it with customisable Admin Columns, Login Customizer, Menu Editor, Activity Logs and much more...​
Admin Columns​
With this module, you can manage and organize the WordPress admin columns into clear, straightforward lists. You can...
CodeCanyon
  • Moderator
CodeCanyon updated WP Adminify PRO - Powerhouse Toolkit for WordPress Dashboard with a new update entry:
3.1.1 NULLED
  • Fixed: User restriction issue fixed for Multisite.
  • Fixed: wp_localize_script object name conflict issue fixed on error-log.js
  • Fixed: WP Memory Usage dashboard widget 'failed to read' issue fixed
  • Fixed: "Phlox WordPress Theme" & "Stackable – Page Builder Gutenberg Blocks" plugins support for hidden adminbar issue fixed
  • Fixed: Freemius SDK updated
  • Fixed: Freemius color issues fixed both on light and dark mode wp
  • Fixed: All in One WP Migration plugin conflict with...
