WP Auto Poster - Automate your site to publish
WP Plugins WP Auto Poster - Automate your site to publish 2.2.2
CodeCanyon
  • Moderator
CodeCanyon submitted a new resource:
WP Auto Poster - Automate your site to publish - CodeCanyon 23805990
WP Auto Poster NULLED makes it easy to manage your WordPress site using intelligent content automation, no matter how many thousands of posts you have. Now you can easily schedule your content to publish, recycle, change or be removed according to flexible rules you supply, all working automatically in the background when you’re not even around.
Put your site’s content on auto-pilot, no matter how complicated! You can easily schedule...
CodeCanyon
  • Moderator
CodeCanyon updated WP Auto Poster - Automate your site to publish with a new update entry:
WP Auto Poster v2.2.2 NULL
= 2.2.2 = Released April 6th, 2023
* function_exists check added for hosts that disable getmypid().
* Moved custom meta field search option to it's own section in Post Conditions.
* Added custom meta field option to the Post Actions tab.
* Combined some setting fields for better visibility.
* Try to catch disabled Ruleset events that are stuck in a cache. Caching cron events is bad. Don't do it.
* Fix for Suppress Filters option defaulting to true. Now defaults to false.
