XenForo 2.1.13 & 2.1.14 Released (Security Fix)
Releases XenForo 2.1.13 & 2.1.14 Released (Security Fix) 2.1.14 Security Patch
XenForo 2.2.11 Released (Security Fix) - XenForo Releases
https://add.pics/images/2022/10/08/Untitled.png
Today, we are releasing XenForo 2.2.11 to address a potential security vulnerability. We recommend that all customers running XenForo 2.2 upgrade to 2.2.11 or use the attached patch file as soon as possible.
The issue relates to HTML attribute injection which can be triggered when rendering editor content, such as when a post is edited or quoted.
XenForo extends thanks to...
XenForo updated XenForo 2.2.11 Released (Security Fix) with a new update entry:
2.1.13 (Security Fix)
Applying a patch manually​
Download the 2113patch.zip file attached to this message. It will contain the following file:
  1. src/XF/BbCode/Renderer/EditorHtml.php
Extract the zip file to your computer and upload the contents to the root of your XenForo installation. This should overwrite the files on your server with the new version.
Note: If you decide to patch the files instead of doing a full upgrade, your "File health check" will report this...
  • #3
    download xenforo 2.1.13 & 2.1.14 released download xenforo 2.1.13 & 2.1.14 released (security fix) download xenforo released (security fix) download xenforo released (security fix) 2.1.13 (security fix) download xenforo released (security fix) 2.1.14 security patch free xenforo 2.1.13 & 2.1.14 released nulled xenforo 2.1.13 & 2.1.14 released nulled xenforo released (security fix) xenforo 2.1.13 & 2.1.14 released xenforo 2.1.13 & 2.1.14 released (security fix) xenforo 2.2.11 released (security fix) 2.2.11 (security fix) xenforo released (security fix) xenforo released (security fix) 2.1.13 (security fix) xenforo released (security fix) 2.1.13 (security fix) download xenforo released (security fix) 2.1.13 (security fix) free xenforo released (security fix) 2.1.13 (security fix) nulled xenforo released (security fix) 2.1.14 security patch xenforo released (security fix) 2.1.14 security patch download xenforo released (security fix) download xenforo released (security fix) nulled xenforo xenforo 2.1.13 & 2.1.14 released xnforo.ir
