The
This will then give a misleading missing function message quite some distance from the root-cause.
Reproducer:
PHP:
XF\Mvc\Entity\Manager::getFinder function is type hinted to return a finder, but if an add-on does not implement the entity name as a short-string, this will fail and instead return the entity.This will then give a misleading missing function message quite some distance from the root-cause.
Reproducer:
PHP:
namespace MyAddon\Entity;
class MyEntity extends \XF\Mvc\Entity\Entity
public static function getStructure(Structure $structure): Structure
