Support XF2 Awards System 1.4.0 Error
nicusor
Hello,
I installed this addon XF2 Add-on - [AddonFlare] XF2 Awards System
but i have some errors and i don't know how to fix it. Can someone help me with this?
XF\CssRenderException: Error rendering template public:extra.less: ParseError: Unexpected input in public:extra.less on line 3645, column 1 (on or near line 3645)
src/XF/CssRenderException.php:87
Stack trace​
 3642 |
 3643 |
 3644 | //////////////////////////.afAwardLevel
*3645*| {
 3646 |     display: inline-block;
 3647 | }
 3648 |
#0 src/XF/CssRenderer.php(416): XF\CssRenderException::createFromLessException(Object(Less_Exception_Chunk), 'public:extra.le...', '// Note that th...')
#1 src/XF/CssRenderer.php(350): XF\CssRenderer->renderToCss('public:extra.le...', '// Note that th...')
#2 src/XF/CssRenderer.php(258): XF\CssRenderer->renderTemplate('public:extra.le...', NULL)
#3 src/XF/CssRenderer.php(116): XF\CssRenderer->renderTemplates(Array, Array, Array)
#4 src/XF/CssWriter.php(53): XF\CssRenderer->render(Array)
#5 css.php(30): XF\CssWriter->run(Array, 9, 1, 'dbd763b61b00570...')
#6 {main}
Previous Less_Exception_Chunk: ParseError: Unexpected input in anonymous-file-0.less on line 3645, column 1
3643|
3644| //////////////////////////.afAwardLevel
3645| {
3646|     display: inline-block;
3647| }
3648|  - src/vendor/oyejorge/less.php/lib/Less/Parser.php:677
#0 src/vendor/oyejorge/less.php/lib/Less/Parser.php(621): Less_Parser->GetRules(NULL)
#1 src/vendor/oyejorge/less.php/lib/Less/Parser.php(449): Less_Parser->_parse()
#2 src/XF/CssRenderer.php(412): Less_Parser->parse('// Note that th...')
#3 src/XF/CssRenderer.php(350): XF\CssRenderer->renderToCss('public:extra.le...', '// Note that th...')
#4 src/XF/CssRenderer.php(258): XF\CssRenderer->renderTemplate('public:extra.le...', NULL)
#5 src/XF/CssRenderer.php(116): XF\CssRenderer->renderTemplates(Array, Array, Array)
#6 src/XF/CssWriter.php(53): XF\CssRenderer->render(Array)
#7 css.php(30): XF\CssWriter->run(Array, 9, 1, 'dbd763b61b00570...')
#8 {main}
Request state​
array(4) {
  ["url"] => string(414) "/css.php?css=public%3Aeditor.less%2Cpublic%3Anode_list.less%2Cpublic%3Ashare_controls.less%2Cpublic%3Asiropu_shoutbox.less%2Cpublic%3Asysnative_improvedstats.less%2Cpublic%3Axentr_statistics.less%2Cpublic%3Axtr_extra_footer.less%2Cpublic%3Axtr_liveBgChooser.less%2Cpublic%3Axtr_message_block.less%2Cpublic%3Axtr_quick_touch.less%2Cpublic%3Aextra.less&s=9&l=1&d=1626428537&k=dbd763b61b0057014f7d684d970fdb3190d097f7"
  ["referrer"] => string(35) "https://www.avengerscs.ro/index.php"
  ["_GET"] => array(5) {
    ["css"] => string(295) "public:editor.less,public:node_list.less,public:share_controls.less,public:siropu_shoutbox.less,public:sysnative_improvedstats.less,public:xentr_statistics.less,public:xtr_extra_footer.less,public:xtr_liveBgChooser.less,public:xtr_message_block.less,public:xtr_quick_touch.less,public:extra.less"
    ["s"] => string(1) "9"
    ["l"] => string(1) "1"
    ["d"] => string(10) "1626428537"
    ["k"] => string(40) "dbd763b61b0057014f7d684d970fdb3190d097f7"
  ["_POST"] => array(0) {
CSS:
/* AVATARS */
.message-avatar-wrapper .avatar.avatar--l {
    width: 200px;
    height: 200px;
    line-height: 1.3;
/* AVATARS */
/* DISTANTA LA PROFIL */
@media (min-width: 651px){
    .message-userTitle + .message-userBanner,
    .message-userExtras,
    .bdMedal_messageUserMedals{
        margin-top: 20px;
/* ICONITE NAV BAR */
.p-navEl a[data-nav-id='steamauth']:before {
    margin-right:2px;
    .m-faBase('Brands');
    .m-faContent("@{fa-var-steam}");
Marks-Man
Hello,
Stack trace​
 3642 |
3643 |
*3645*| {
3647 | }
3648 |
#6 {main}
3643|
3645| {
3647| }
#8 {main}
Request state​
array(4) {
1.40 is for XenForo 2.2.2 and it is unmaintained project !
nicusor
This is what i have in extra.less
/// AVATARS ////
    width: 200px;
    height: 200px;
    line-height: 1.3;
/// AVATARS ////
// DISTANTA LA PROFIL
        margin-top: 20px;
//////////////////////////// ICONITE NAV BAR ////////////////////////////
    margin-right:2px;
Marks-Man
/// AVATARS ////
    width: 200px;
    height: 200px;
    line-height: 1.3;
/// AVATARS ////
        margin-top: 20px;
    margin-right:2px;
You can't add // in extra less.
It will crash, just remove the slashes ;)
To comment in CSS, simply place your plain text inside /* */ marks.
