[XTR] User Group Avatar Frame - Best way to add a avatar frame per each user groups via selectable colors
This add-on allows you to add a avatar frame by selected user group frame color.
XenForo 2.2.x Compatibility
Note: Please do not install the add-on, if you are using lower than XF 2.2.2
- Requires PHP 7.2+
- Supports only XF 2.2.2+
This version only support to XF 2.2.2+...
