Does anyone know how to install Ztense Torrent tracker and H&R and get it working
I have some links but it doesn't quite work.
XBT Tracker
Installation
XBT Tracker
Installation
Hello! Have you found a solution to this? Just got the same errorhttps://bajubesi.org/v2/threads/ztense-torrent-tracker-2-2-17-4-tutorial.27/
Most of us not connect the server with the database provide by the addon, the server and the addon need to connect on the same database, that's how i make the server side online.i found out that we cannot use other xbt_tracker e.g from github binary it cannot run with the database we setup with addon,i still trying to figure why is that, it's seems like the xbt binary from github missing config name.
Bash:WARNING: MYSQL_OPT_RECONNECT is deprecated and will be removed in a future version. unknown config name: cheat_system unknown config name: cloudfare unknown config name: download_multiplier unknown config name: freeleech unknown config name: global_multiplier unknown config name: read_db_files_interval unknown config name: read_db_users_interval unknown config name: seedbonus unknown config name: seedbonus_interval unknown config name: upload_multiplier Unknown column 'tid' in 'field list' select tid, uid, active, completed, downloaded, `left`, uploaded from xftt_peer where 0
Yes. I reinstalled my server to Ubuntu 22.04.4 and followed the guideHow did you solved it, just by re-installation?
could someone post this tutorial here please
I can send it in PM if you want?could someone post this tutorial here please
