Support my site says its in maintenance mode
juice213
my site says it's in maintenance mode when I didn't put it in it and I can't access the ACP to turn it off.
this is what it says I don't know if it's a plugin or not.
it doesn't say this on the landing page any the forum part of the site so I'm confused why its doing this now
Take back control of your Cpanel :
In your file : config.php ( src/config.php )
Add : $config['enableListeners'] = false;
Then you can deactivate your addons !
this didn't work
so how would I remove that without losing the hole forum again or will I need to reinstall the whole thing
I saw you have re-installed the Xenforo as new. You didn't have to do it. Only thing you needed is patience, which I am afraid, you don't have. Your lack of patience might cost you dearly in future, if you don't change that. You should keep it in mind when you ask for support here or any other free forum that, you are getting support for FREE and we do have to work for our livelihood. We give support here at our free time. So you have to be patient to get the answer.
@XenForo Friend, should you lock this thread as no further support is needed on this query? You decide.
