Support Problems with image size
micke
After the update to version 2.2.4 from 2.2.3, my pictures will be wide, as wide as the picture is in reality.
It is not possible to set, for example, 300 x 250, the image will be 800 x 600 as it is.
This will be the case both in the Article system and for the Download page.
Has anyone else had the same problem after the update to Version 2.2.4?
micke
So weird. Do not know what could be wrong.
I solved it in another way, instead of setting the height of the pictures, I set the width of the picture, then it will be fine.
I will continue to search for the error why you get "Your IP address has been blocked." apologize for that.
There were bugs for the images you mentioned in previous versions, but they were fixed in versions 2.2.3 and above. You are probably using a CDN to block the IP, or your server administrator has blocked Iranian IPs
    image size
