Urs worked bcs u had sticky navigation but if u use no sticky nav then again it will be left out above
Like I have and it wont show below bcs of no sticky nav
Still can't figure out, which theme are you working on? I've tried 5 different themes all with no problems. You can't have both options enabled bottom and top progress bar at same time, you need to turn off the unused one, like I did in video otherwise this problem will trigger because I didn't handle it. which option is not working? I tested on 2.2.5 templates. are you working on 2.2.5 templates?
Yours is working bcs u have sticky navigation enabled
while since I don't and the navigation progress bar is stuck with the navigation or admin bar one of those
simply move the progress bar above admin bar and it might be fixed
(Try disabling sticky nav on your forum and u might see it)
