XF2 [8WR] XenPorta 2 (Portal) PRO
Add-ons XF2 [8WR] XenPorta 2 (Portal) PRO 2.2.0.7
  • #6
XenForo updated XF2 [8WR] XenPorta 2 (Portal) PRO with a new update entry:
2.2.0.4 - CHANGELOG
This update redesigns some of the styles of the default portal page. Check your style properties.
  • You can now define fixed width heights of your message bodies on the articles list.
    • If you use fixed widths, the addon will automatically disable the masonry library.
    • If you use image headers, the message body height will be automatically adjusted.
  • You can now choose to display a simpler "continue" button for the articles list.
  • Promoting a thread will now...
  • #7
    download xf2 [8wr] xenporta 2 (portal) pro xenforo xf2 [8wr] xenporta 2 (portal) pro xf2 [8wr] xenporta 2 (portal) pro xf2 [8wr] xenporta 2 (portal) pro 2.2.0.7 xf2 [8wr] xenporta 2 (portal) pro xnforo
