Make sure to backup DB From PHPMyAdmin, same process can be used but make sure 2FA is set to "0"yes bro but how to do that from database.
btw bro how do i disable the 2fa only or just disable the dbtech security from phpmyadmin?Make sure to backup DB From PHPMyAdmin, same process can be used but make sure 2FA is set to "0"
XenForo - Recover XenForo Admin Password via phpMyAdmin!
You will need to edit or update the following tables(as needed): xf_user xf_user_option xf_user_authenticate xf_admin (In this Tutorial I created new User with ID number 5 , with username named : "Moro" & Password "1234" You can edit as needed: INSERT INTO `xf_user` (`user_id`, `username`...xnforo.ir
dbtech security addon is complete mess, just check dbtech table and make changesbtw bro how do i disable the 2fa only or just disable the dbtech security from phpmyadmin?
HI, I understand you get asked this every time you want to log-in, IF you can get access to your CP (control panel) go into ACP > Groups & Permissions > Administrative > General Permissions > Require two-step verification = SET TO NO / NEVER and save
