got that fixed thanksdbtech security addon is complete mess, just check dbtech table and make changes
At least for Xenforo, I suggest, you should ask here before installing any plugin. If possible, ask for your requirement and recommended plugin or way to do that in the support section and you will get best answers from Masters here. Do as per their suggestions and your life will be in peace.got that fixed thanks
k bro ty.At least for Xenforo, I suggest, you should ask here before installing any plugin. If possible, ask for your requirement and recommended plugin or way to do that in the support section and you will get best answers from Masters here. Do as per their suggestions and your life will be in peace.![]()
Every add-on in Xenforo has a 'Rebuild' option. If you click that, all data for that particular plugin will be reset to default. You can also use that and setup the 2FA again.
yes bro ty btw bro how to add Free Image Hosting when every member trying to post image on thread or in forum?Every add-on in Xenforo has a 'Rebuild' option. If you click that, all data for that particular plugin will be reset to default. You can also use that and setup the 2FA again.
