More major updates to the front portal. Make sure to check your style properties as a lot of settings have changed.
There are now easy options to hide the majority of article elements in case you wish to make an image based grid. Disabling expanded article elements will place some article attribution data into the image header. If you do want to use an image grid, you should make your Masonry baseline height and Article image header height equal. You should also increase the...
yea i finaly notice! edit --> this is not going to work cause if you look at youtube for info,you'l see its not the same version,so might as well wait for the 2.2.0.7 version, thanks anyway friend!
