Standard Library by Xon
Add-ons Standard Library by Xon 1.22.6
XenForo updated Standard Library by Xon with a new update entry:
1.13.0 - Feature update
  • Add is_toggle_set template function and toggle-storage-ex backend for the XF toggle JS.
    The stock is_toggled does not allow setting the default value, while is_toggle_set does.
  • Example of a default collapsed node-list:
PHP:
<xf:js src="sv/lib/storage.js" addon="SV/StandardLib" min="1" />
<xf:set var="$isActive" value="{{ is_toggle_set($forum.node_id, false, 'node-toggle') ? ' is-active' : '' }}"/>
<div...
mRX
Please could you fix this. File health check showing unexcepted files after installed this plugin,
1.13.0 fixed
PHP:
<div...
  • Love
Reactions: mRX
    add on standard library by xon download free addons download nulled addons download standard library by xon 1.13.0 download standard library by xon 1.13.1 download standard library by xon 1.14.0 download standard library by xon 1.15.0 download standard library by xon 1.15.2 download xenforo addons download xenforo styles free addons xenforo nulled addons nulled standard library by xon standard library by xon 1.10.2 standard library by xon 1.11.1 standard library by xon 1.11.2 standard library by xon 1.12.0 standard library by xon 1.12.1 standard library by xon 1.12.2 standard library by xon 1.13.0 standard library by xon 1.13.1 standard library by xon 1.14.0 standard library by xon 1.15.0 standard library by xon 1.15.2 standard library by xon 1.16.0 standard library by xon 1.16.1 standard library by xon 1.17.0 standard library by xon 1.18.0 standard library by xon 1.18.2 standard library by xon 1.18.3 standard library by xon 1.18.4 standard library by xon 1.19.0 standard library by xon 1.19.3 standard library by xon 1.19.4 standard library by xon 1.19.5 standard library by xon 1.20.0 standard library by xon 1.20.1 standard library by xon 1.21.10 standard library by xon 1.21.11 standard library by xon 1.21.13 standard library by xon 1.21.14 standard library by xon 1.21.15 standard library by xon 1.21.6 standard library by xon 1.21.9 standard library by xon 1.22.2 standard library by xon 1.22.3 standard library by xon 1.22.4 standard library by xon 1.22.5 standard library by xon 1.22.6 standard library by xon 1.6.0 standard library by xon 1.7.1 patch 1 standard library by xon 1.7.2 standard library by xon 1.7.3 standard library by xon 1.8.0 standard library by xon 1.8.1 standard library by xon 1.8.2 standard library by xon 1.9.0 xenforo 2 xenforo 2 add-ons xenforo nulled community xenforo standard library by xon xenforo support xnforo.ir انجمن های پشتیبانی زنفورو انجمن پشتیبانی زنفورو انجمن پشتیبانی زنفورو فارسی زنفورو فارسی پشتیبان رسمی زنفورو پشتیبان زنفورو پشتیبان فارسی زنفورو
