Standard Library by Xon
Add-ons Standard Library by Xon 1.23.0
XenForo updated Standard Library by Xon with a new update entry:
1.18.0 - Feature update
  • Add support for addon.json 'require'/'require-soft' to support addon version strings instead of the addon version_id.
    Uses version_compare under the hood after some very basic standardization.
    php version strings support dotted versions, '1.2.3' and also each part may also support special character strings:
    any string not found in this list < dev < alpha = a < beta = b < RC | Release Candidate =...
1.18.2 - Mini-feature & bugfix update
Note; The 1.18.x branch will be the last branch to support XenForo 2.1.x
  • Deprecate getContentPermissions function, as the 2nd string argument was not actually used, with a replacement function getPerContentPermissions added.
  • Add \SV\StandardLib\Helper::isAddOnActive() helper function. Similar to \XF::isAddonActive(), except it understands version strings
  • Shim template funciton is_addon_active code to understand version strings
Standard Library by Xon 1.19.0
  • Only add phrase_dynamic template method in XF2.1
  • Add various strongly typed helpers to automatically type hint returns based on using ::class argument instead of magic strings.
    PHP:
    $obj = Helper::repository(\XF\Repository\User::class);
    For static analysis and IDE, $obj will have the type \XF\Repository\User
    While XF2.3 intends to implement this, adding this functionality to this add-on allows migrating...
    add on standard library by xon download free addons download nulled addons download standard library by xon 1.13.0 download standard library by xon 1.13.1 download standard library by xon 1.14.0 download standard library by xon 1.15.0 download standard library by xon 1.15.2 download xenforo addons download xenforo styles free addons xenforo nulled addons nulled standard library by xon standard library by xon 1.10.2 standard library by xon 1.11.1 standard library by xon 1.11.2 standard library by xon 1.12.0 standard library by xon 1.12.1 standard library by xon 1.12.2 standard library by xon 1.13.0 standard library by xon 1.13.1 standard library by xon 1.14.0 standard library by xon 1.15.0 standard library by xon 1.15.2 standard library by xon 1.16.0 standard library by xon 1.16.1 standard library by xon 1.17.0 standard library by xon 1.18.0 standard library by xon 1.18.2 standard library by xon 1.18.3 standard library by xon 1.18.4 standard library by xon 1.19.0 standard library by xon 1.19.3 standard library by xon 1.19.4 standard library by xon 1.19.5 standard library by xon 1.20.0 standard library by xon 1.20.1 standard library by xon 1.21.10 standard library by xon 1.21.11 standard library by xon 1.21.13 standard library by xon 1.21.14 standard library by xon 1.21.15 standard library by xon 1.21.6 standard library by xon 1.21.9 standard library by xon 1.22.2 standard library by xon 1.22.3 standard library by xon 1.22.4 standard library by xon 1.22.5 standard library by xon 1.22.6 standard library by xon 1.23.0 standard library by xon 1.6.0 standard library by xon 1.7.1 patch 1 standard library by xon 1.7.2 standard library by xon 1.7.3 standard library by xon 1.8.0 standard library by xon 1.8.1 standard library by xon 1.8.2 standard library by xon 1.9.0 xenforo 2 xenforo 2 add-ons xenforo nulled community xenforo standard library by xon xenforo support xnforo.ir انجمن های پشتیبانی زنفورو انجمن پشتیبانی زنفورو انجمن پشتیبانی زنفورو فارسی زنفورو فارسی پشتیبان رسمی زنفورو پشتیبان زنفورو پشتیبان فارسی زنفورو
