Standard Library by Xon
Add-ons Standard Library by Xon 1.24.1
XenForo updated Standard Library by Xon with a new update entry:
Standard Library by Xon 1.21.14
  • Update to choices.js v11.0.4
    • Fix selected option being escaped twice (Affects MultiPrefix editing a thread prefix)
    • Fix reaching maximum item limit notice is not cleared after removing selections
    • Fix tab => direction keys handling
    • Fix performance regression when loading options after choices.js object creation (Affects MultiPrefix loading per-forum prefixes)
Standard Library by Xon 1.22.2
  • Workaround unexpected behavior in \XF::options() and strongly typed property hints (generated by XF CLI command xf-dev:generate-options-stub) which may cause bugs in some add-ons
  • Update choices.js v11.1.0
    • Remove role="textbox" from search input, per a11y practices
    • Add choices.search-kmp.js build, more advanced than a simple prefix match but less complex than using FUSE for search
    • Support <option label="..."...
    add on standard library by xon download free addons download nulled addons download standard library by xon 1.13.0 download standard library by xon 1.13.1 download standard library by xon 1.14.0 download standard library by xon 1.15.0 download standard library by xon 1.15.2 download xenforo addons download xenforo styles free addons xenforo nulled addons nulled standard library by xon standard library by xon 1.10.2 standard library by xon 1.11.1 standard library by xon 1.11.2 standard library by xon 1.12.0 standard library by xon 1.12.1 standard library by xon 1.12.2 standard library by xon 1.13.0 standard library by xon 1.13.1 standard library by xon 1.14.0 standard library by xon 1.15.0 standard library by xon 1.15.2 standard library by xon 1.16.0 standard library by xon 1.16.1 standard library by xon 1.17.0 standard library by xon 1.18.0 standard library by xon 1.18.2 standard library by xon 1.18.3 standard library by xon 1.18.4 standard library by xon 1.19.0 standard library by xon 1.19.3 standard library by xon 1.19.4 standard library by xon 1.19.5 standard library by xon 1.20.0 standard library by xon 1.20.1 standard library by xon 1.21.10 standard library by xon 1.21.11 standard library by xon 1.21.13 standard library by xon 1.21.14 standard library by xon 1.21.15 standard library by xon 1.21.6 standard library by xon 1.21.9 standard library by xon 1.22.2 standard library by xon 1.22.3 standard library by xon 1.22.4 standard library by xon 1.22.5 standard library by xon 1.22.6 standard library by xon 1.23.0 standard library by xon 1.23.3 standard library by xon 1.23.5 standard library by xon 1.23.7 standard library by xon 1.6.0 standard library by xon 1.7.1 patch 1 standard library by xon 1.7.2 standard library by xon 1.7.3 standard library by xon 1.8.0 standard library by xon 1.8.1 standard library by xon 1.8.2 standard library by xon 1.9.0 xenforo 2 xenforo 2 add-ons xenforo nulled community xenforo standard library by xon xenforo support xnforo.ir انجمن های پشتیبانی زنفورو انجمن پشتیبانی زنفورو انجمن پشتیبانی زنفورو فارسی زنفورو فارسی پشتیبان رسمی زنفورو پشتیبان زنفورو پشتیبان فارسی زنفورو
