Standard Library by Xon
Add-ons Standard Library by Xon 1.24.1
XenForo updated Standard Library by Xon with a new update entry:
Standard Library by Xon 1.22.5
  • Partial workaround for buggy XF2.3 behavior around repository uniqueness. Does not affect call sites to \XF::repository, only Helper::repository
  • Fix incorrectly using SqlJoinTrait would swallow the actual error
  • Improve detection of excluding non-required joins when using EarlyJoinFinderTrait. This affects Multi Prefix is optimizing for matching on a single prefix, and also...
Standard Library by Xon 1.23.0
  • Fix bad type-hint on whereImpossible() method for EarlyJoinFinderTrait trait
  • Update Helper::newExtendedClass() to execute in the context of the class being executed, this allows private/protected constructors to be called
  • Add tab-nav helper code to work with collapsible sections (sv/lib/tab-nav.js), this allows tabbing between elements to trigger collapsing/expanding of collapsed sections
  • Add support for 3rd party add-ons...
    add on standard library by xon download free addons download nulled addons download standard library by xon 1.13.0 download standard library by xon 1.13.1 download standard library by xon 1.14.0 download standard library by xon 1.15.0 download standard library by xon 1.15.2 download xenforo addons download xenforo styles free addons xenforo nulled addons nulled standard library by xon standard library by xon 1.10.2 standard library by xon 1.11.1 standard library by xon 1.11.2 standard library by xon 1.12.0 standard library by xon 1.12.1 standard library by xon 1.12.2 standard library by xon 1.13.0 standard library by xon 1.13.1 standard library by xon 1.14.0 standard library by xon 1.15.0 standard library by xon 1.15.2 standard library by xon 1.16.0 standard library by xon 1.16.1 standard library by xon 1.17.0 standard library by xon 1.18.0 standard library by xon 1.18.2 standard library by xon 1.18.3 standard library by xon 1.18.4 standard library by xon 1.19.0 standard library by xon 1.19.3 standard library by xon 1.19.4 standard library by xon 1.19.5 standard library by xon 1.20.0 standard library by xon 1.20.1 standard library by xon 1.21.10 standard library by xon 1.21.11 standard library by xon 1.21.13 standard library by xon 1.21.14 standard library by xon 1.21.15 standard library by xon 1.21.6 standard library by xon 1.21.9 standard library by xon 1.22.2 standard library by xon 1.22.3 standard library by xon 1.22.4 standard library by xon 1.22.5 standard library by xon 1.22.6 standard library by xon 1.23.0 standard library by xon 1.23.3 standard library by xon 1.23.5 standard library by xon 1.23.7 standard library by xon 1.6.0 standard library by xon 1.7.1 patch 1 standard library by xon 1.7.2 standard library by xon 1.7.3 standard library by xon 1.8.0 standard library by xon 1.8.1 standard library by xon 1.8.2 standard library by xon 1.9.0 xenforo 2 xenforo 2 add-ons xenforo nulled community xenforo standard library by xon xenforo support xnforo.ir انجمن های پشتیبانی زنفورو انجمن پشتیبانی زنفورو انجمن پشتیبانی زنفورو فارسی زنفورو فارسی پشتیبان رسمی زنفورو پشتیبان زنفورو پشتیبان فارسی زنفورو
