Standard Library by Xon
Add-ons Standard Library by Xon 1.24.1
XenForo updated Standard Library by Xon with a new update entry:
Standard Library by Xon 1.21.2
  • Fix ajax pagination & ajax filtered pagination code did not dynamically loading css/js
  • Update choices.js
    • Various performance fixes when used with large number of options (ie hundreds of prefixes when using Multi-Prefix)
    • Fix filtering/search could return unstable search results
    • Fix possible empty ar-liaabel generation on remove item button
    • Fix enter could cause accidental form submit instead of open/closing the choices list in all...
Standard Library by Xon 1.21.9
  • Update choices.js
    • Adjust font-size css to be more inline with standard XF
    • Fix select did not reset correct after a form submit.
      • Noticeable with Threadmarks Pro add-on on replying to a thread
    • Fix "no choices to choose from"/"no results found" notice did not reliably trigger
    • Fix options loader would unexpectedly clear options. This impacts the move thread function.
  • Update count down timer to only show seconds in the last 2 minutes by...
    add on standard library by xon download free addons download nulled addons download standard library by xon 1.13.0 download standard library by xon 1.13.1 download standard library by xon 1.14.0 download standard library by xon 1.15.0 download standard library by xon 1.15.2 download xenforo addons download xenforo styles free addons xenforo nulled addons nulled standard library by xon standard library by xon 1.10.2 standard library by xon 1.11.1 standard library by xon 1.11.2 standard library by xon 1.12.0 standard library by xon 1.12.1 standard library by xon 1.12.2 standard library by xon 1.13.0 standard library by xon 1.13.1 standard library by xon 1.14.0 standard library by xon 1.15.0 standard library by xon 1.15.2 standard library by xon 1.16.0 standard library by xon 1.16.1 standard library by xon 1.17.0 standard library by xon 1.18.0 standard library by xon 1.18.2 standard library by xon 1.18.3 standard library by xon 1.18.4 standard library by xon 1.19.0 standard library by xon 1.19.3 standard library by xon 1.19.4 standard library by xon 1.19.5 standard library by xon 1.20.0 standard library by xon 1.20.1 standard library by xon 1.21.10 standard library by xon 1.21.11 standard library by xon 1.21.13 standard library by xon 1.21.14 standard library by xon 1.21.15 standard library by xon 1.21.6 standard library by xon 1.21.9 standard library by xon 1.22.2 standard library by xon 1.22.3 standard library by xon 1.22.4 standard library by xon 1.22.5 standard library by xon 1.22.6 standard library by xon 1.23.0 standard library by xon 1.23.3 standard library by xon 1.23.5 standard library by xon 1.23.7 standard library by xon 1.6.0 standard library by xon 1.7.1 patch 1 standard library by xon 1.7.2 standard library by xon 1.7.3 standard library by xon 1.8.0 standard library by xon 1.8.1 standard library by xon 1.8.2 standard library by xon 1.9.0 xenforo 2 xenforo 2 add-ons xenforo nulled community xenforo standard library by xon xenforo support xnforo.ir انجمن های پشتیبانی زنفورو انجمن پشتیبانی زنفورو انجمن پشتیبانی زنفورو فارسی زنفورو فارسی پشتیبان رسمی زنفورو پشتیبان زنفورو پشتیبان فارسی زنفورو
